Review System Nodes
Use the System-Node Review tool to find the nodes that have a local reference system or analysis system attached.
View new features for HyperWorks 2022.3.
Setup an Optimization in HyperWorks.
Create an assembly structure from a .csv file definition.
Use the Quick Coord Creation tool to create a system using beam or shell elements.
Allows you to have the same system defined in both HyperMesh and HyperView.
