AVEVA Marine Reader
Supported Entities
- Plane panels
- Curved panels
- Knuckled panels
- Plane plates
- Curved plates
- Pillars
- Stiffeners (also with sub-flanges)
- Curved stiffeners
- Face plates (also with sub-flanges)
- Flanges
- Brackets
- Doubling profiles
- Hole profiles
- Marking profiles
- Seam profiles
- Swage profiles
- Tap profiles
@CreationType
= TreeOfComponents
, an assembly
tree is created and organized as follows:- 1 assembly corresponding to the whole ship (1 ship per part).
- 1 assembly per block.
- 1 assembly per PlanePanel.
- 1 component for the detailed contour of the current PlanePanel (with relevant option).
- 1 component for the simple contour of the current PlanePanel (with relevant option).
- 1 component per PlanePlateGroup. The material name, material
side, thickness and offset are created as metadata. If
material data are available, a PSHELL material is
created.
- 1 surface per PlanePlate. The profile existing in the file is used for the external loop. Holes can be added as internal loops (with relevant option).
- 1 component per PlanePillarGroup.
- 1 set of trace lines per PlanePillar.
- 1 surface per web (with relevant option).
- 1 component per PlaneFlangeGroup.
- 1 set of trace lines per PlaneFlange.
- 1 component per PlaneStiffenerGroup.
- 1 set of trace lines per PlaneStiffener.
- 1 surface per web and per flange (with relevant option).
- 1 component per PlaneFaceplateGroup.
- 1 set of trace lines per PlaneFaceplate.
- 1 assembly per sub-PlanePanel. The contents correspond to the ones for normal PlanePanels.
- 1 assembly per PlaneBracketGroup.
- 1 component per bracket if no sub-elements exist
(stiffeners, planeplates, flanges). 1 assembly if
sub-elements exist.
- 1 surface per PlaneBracket. The profile existing in the file is used for the external loop. No holes are allowed by the AVEVA Marine format. If sub-elements are present in the current PlaneBracketGroup, a specific component is created for the surface in order to keep it separate from its sub-elements.
- 1 component per PlaneStiffenerGroup sub-element (no flanges inside the stiffener group are allowed).
- 1 component per PlaneFaceplateGroup sub-element (no flanges inside the faceplate group are allowed).
- 1 component per PlaneFlangeGroup sub-element.
sub-elements exist.
- 1 assembly per CurvedPanel.
- 1 component for the simple contour of the current CurvedPanel (with relevant option).
- 1 component per CurvedPlateGroup.
- 1 surface per CurvedPlate. The profile existing in the file is used for the external loop. Internal holes are implemented.
- 1 component per CurvedStiffenerGroup.
- 1 set of trace lines per CurvedStiffener.
- 1 assembly per KnuckledPanel.
When @CreationType
is “Parts
”, a corresponding tree
is created but no assembly entities are created, parts are created instead. The
components are also created.
When @CreationType
is “BOM Only
”, a corresponding
tree is created with parts as in the previous case, but no components are actually
created.
PlanePlates, CurvedPlates and PlaneBrackets are mapped as surfaces. Other objects are imported as curves, lying on the plates. Groups of objects may share similar properties (such as material, material side, thickness and offset). In this case, metadata are added to these objects, and if possible the material description is also created. Holes of curved surfaces are not taken into consideration for this release.
The reader instantiates objects in their nominal position, hence there may be gaps between panels, brackets, and so forth, due to idealizations that do not take thickness into account. Hence, no stitching between surfaces is performed on import.
Available material fields include Young's modulus, Poisson's ratio, expansion coefficient, and density. Yield stress and ultimate stress are not imported. Each material is associated with a unique grade name.
When a thickness is provided, the corresponding value is given to a HyperWorks properties.
Objects affected by material/thickness include PlanePlateGroup, PlanePillarGroup, PlaneFlangeGroup, PlaneStiffenerGroup, PlaneFaceplateGroup, PlaneBracketGroup, CurvedPlateGroup and CurvedStiffenerGroup.
Import Options
@BodyIdAsMetadata
Value | Description |
on |
Assign body identifier as
metadata.
off |
Do not assign body identifier as metadata (default). |
@CleanupTol
double |
A negative value (default) indicates to use the auto cleanup tolerance. A value greater than the calculated auto cleanup tolerance indicates to use that specific tolerance. Refer to the CAD Cleanup Tolerance. |
@ColorsAsMetadata
integer |
Read color attributes of geometric entities as metadata with integer values.
on |
Read color attributes of geometric entities as metadata.
off |
Do not read color attributes (default). |
@CreationType
Parts |
Generate a full part-based hierarchy. |
BOMOnly |
Generate an empty part-based hierarchy. |
TreeOfComponents |
Generate an assemblies/components based hierarchy. |
PackIntoSinglePart |
Consolidate hierarchy into a single part. |
@CurvedPlateColor
string |
A RGB description of the color to use for curved plates, with values ranging
from 0.0 to 1.0 (for example "0.1,0.5,0.4"). If not specified, default color
management will be utilized. The obsolete @TribonCurvedPlateColor
is corresponding to this option and still supported. |
@CurvedSimpleContourColor
string |
A RGB description of the color to use for curved simple contours, with values
ranging from 0.0 to 1.0 (for example "0.1,0.5,0.4"). If not specified, default color
@TribonCurvedSimpleContourColor is corresponding to this option
@CurvedStiffenerColor
string |
A RGB description of the color to use for curved stiffeners, with values
ranging from 0.0 to 1.0 (e.g. "0.1,0.5,0.4"). If not specified, default color
@TribonCurvedStiffenerColor is corresponding to this option and
still supported. |
@DoNotMergeEdges
on |
Preserve the original geometry edges, instead of merging them together during the import cleanup phase. |
off |
Merge edges together during the import cleanup phase (default). |
@ExtendSurfaces
on |
The imported surfaces are extended to match neighbor surfaces (default). |
off |
The imported surfaces are not extended. |
@FlangeColor
string |
A RGB description of the color to use for flanges, with values ranging from 0.0
to 1.0 (for example "0.1,0.5,0.4"). If not specified, default color management will
be utilized. The obsolete @TribonFlangeColor is corresponding to
@ImportCutoutProfiles
on |
Import cutout profiles. |
off |
Do not import cutout profiles (default). |
@ImportDoublingProfiles
on |
Import doubling profiles. |
off |
Do not import doubling profiles (default). |
@ImportFaceplatesAsSurfaces
on |
Import faceplates as surfaces if the surface description is present in the file, otherwise import as curves (default). |
off |
Import faceplates as curves. |
@ImportHoleProfiles
on |
Import hole profiles. |
off |
Do not import hole profiles (default). |
@ImportHoles
on |
Create holes (default). |
off |
Do not create create holes. |
@ImportMarkingProfiles
on |
Import marking profiles. |
off |
Do not import marking profiles (default). |
@ImportNotchProfiles
on |
Import notch profiles. |
off |
Do not import notch profiles (default). |
@ImportPanelProfiles
on |
Create curves along the panel profiles. |
off |
Do not create curves along the panel profiles (default). |
@ImportPillarsAsSurfaces
on |
Import pillars as surfaces if the surface description is present in the file, otherwise import as curves (default). |
off |
Import pillars as curves. |
@ImportSeamProfiles
on |
Import seam profiles. |
off |
Do not import seam profiles (default). |
@ImportStiffenersAsSurfaces
on |
Import stiffeners as surfaces if the surface description is present in the file, otherwise import as curves (default). |
off |
Import stiffeners as curves. |
@ImportSwageProfiles
on |
Import swage profiles. |
off |
Do not import swage profiles (default). |
@ImportTapProfiles
on |
Import tap profiles. |
off |
Do not import tap profiles (default). |
@ImportUnboundedCurvedPlates
on |
Import curved plates lacking boundary descriptions (default). |
off |
Do not import curved plates lacking boundary descriptions. |
@ImprintStiffeners
on |
Stiffener lines are projected onto close surfaces and create corresponding topological modifications to these surfaces (default). |
off |
No projection is performed. |
@LegacyHierarchyAsMetadata
on |
Generate metadata with the original CAD hierarchy within the
part.
off |
Do not generate metadata with the original CAD hierarchy within the part (default). |
@MetadataPrefix
string |
The string is prefixed to all metadata names. No prefix is used by
default. See CAD Metadata Naming for more details. |
@PlaneBracketColor
string |
A RGB description of the color to use for plane brackets, with values ranging
management will be utilized. The obsolete @TribonPlaneBracketColor
@PlaneCutoutColor
string |
A RGB description of the color to use for plane cutouts, with values ranging from 0.0 to 1.0 (for example "0.1,0.5,0.4"). If not specified, default color management will be utilized. |
@PlaneDetailedContoursColor
string |
A RGB description of the color to use for plane detailed contours, with values
@TribonPlaneDetailedContoursColor is corresponding to this option
@PlaneDoublingColor
string |
A RGB description of the color to use for plane doublings, with values ranging from 0.0 to 1.0 (for example "0.1,0.5,0.4"). If not specified, default color management will be utilized. |
@PlaneFaceplateColor
string |
A RGB description of the color to use for plane faceplates, with values ranging
@TribonPlaneFaceplateColor is corresponding to this option and
still supported. |
@PlaneFlangeColor
string |
A RGB description of the color to use for plane flanges, with values ranging
management will be utilized. The obsolete @TribonPlaneFlangeColor
@PlaneHoleColor
string |
A RGB description of the color to use for plane hole profiles, with values ranging from 0.0 to 1.0 (for example "0.1,0.5,0.4"). If not specified, default color management will be utilized. |
@PlaneMarkingColor
string |
A RGB description of the color to use for plane marking profiles, with values ranging from 0.0 to 1.0 (for example "0.1,0.5,0.4"). If not specified, default color management will be utilized. |
@PlaneNotchColor
string |
A RGB description of the color to use for plane notch profiles, with values ranging from 0.0 to 1.0 (for example "0.1,0.5,0.4"). If not specified, default color management will be utilized. |
@PlanePillarColor
string |
A RGB description of the color to use for plane pillars, with values ranging
management will be utilized. The obsolete @TribonPlanePillarColor
@PlanePlateColor
string |
A RGB description of the color to use for plane plates, with values ranging
management will be utilized. The obsolete @TribonPlanePlateColor is
@PlaneSeamColor
string |
A RGB description of the color to use for plane seam profiles, with values ranging from 0.0 to 1.0 (for example "0.1,0.5,0.4"). If not specified, default color management will be utilized. |
@PlaneSimpleContourColor
string |
A RGB description of the color to use for plane simple contours, with values
@TribonPlaneSimpleContourColor is corresponding to this option
@PlaneStiffenerColor
string |
A RGB description of the color to use for plane stiffeners, with values ranging from 0.0 to 1.0 (for example "0.1,0.5,0.4"). If not specified, default color management will be utilized. The obsolete @TribonPlaneStiffenerColor is corresponding to this option and still supported. |
@PlaneSwageColor
string |
A RGB description of the color to use for plane swage profiles, with values ranging from 0.0 to 1.0 (for example "0.1,0.5,0.4"). If not specified, default color management will be utilized. |
@PlaneTapColor
string |
A RGB description of the color to use for plane tap profiles, with values ranging from 0.0 to 1.0 (for example "0.1,0.5,0.4"). If not specified, default color management will be utilized. |
@PreferDetailed
on |
When multiple representations of a AVEVA Marine object are available, import the most complex one (default). |
off |
When multiple representations of a AVEVA Marine object are available, import the least complex one. |
@ScaleFactor
double |
Define the model scaling factor during import. Default is 1.0. |
@SplitComponents
Part |
Generate part-based component (only allowed value if
CreationType =Parts ). |
General |
Keep component as in CAD (only allowed value if
CreationType =TreeOfComponents ). |
@StitchEdges
on |
Edges of close surfaces are stitched together (default). |
off |
Edges of close surfaces are not stitched together. |
@SubFaceplateColor
string |
A RGB description of the color to use for sub-faceplates, with values ranging
management will be utilized. The obsolete @TribonSubFaceplateColor
@SubStiffenerColor
string |
A RGB description of the color to use for sub-stiffeners, with values ranging
management will be utilized. The obsolete @TribonSubStiffenerColor
@TargetUnits
CAD units |
Keep the units of the CAD files (default for GUI). |
MKS [m kg N s] |
Convert to the corresponding units system. |
MMKS [mm kg N s] |
MPA [mm t N s] |
CGS [cm g dyn s] |
MMKNMS [mm kg kN ms] |
MMGNMS [mm g N ms] |
IPS Std [in pounds lbf s] |
IPS Grav [in slinch lbf s] |
FPS Std [ft pounds lbf s] |
FPS Grav [ft slug lbf s] |
Scale factor |
Apply the corresponding scale factor (default for no GUI to allow supporting legacy scripts). |
Supported Metadata
AVEVA_OBJECT_TYPE
Type | Entities | Description |
string |
comps, assems if hierarchy as Assemblies; parts if hierarchy as Parts | The value is a string indicating the role of the object. Currently created
values include:
BEAM_SECTION
entity |
parts | Stiffener groups might contain this metadata which points the corresponding BEAMSECTION entity. |
BEND_TYPE
string |
comps, assems if hierarchy as Assemblies; parts if hierarchy as Parts | The value of the BendingRadius attribute for a plane faceplate group, a plane
flange group, a plane pillar group, or a plane stiffener group. Possible values are:
BENDING_RADIUS
string |
comps, assems if hierarchy as Assemblies; parts if hierarchy as Parts | The value of the BendingRadius attribute for a plane flange group. |
BODY_ID
string |
Identifier of the CAD body containing the entity. Generated when
COLOR_RGB
string |
Three RGB values, ranging from 0 to 255, indicating the color for the object. Generated when the corresponding |
COMP_ID
string |
surfs | The value of the CompId attribute for a plate or bracket. |
DATA_TYPE
string |
assems if hierarchy as Assemblies; parts if hierarchy as Parts | The value of the DataType attribute for a panel. |
EXTENT_MAX
string |
assems if hierarchy as Assemblies; parts if hierarchy as Parts | The value of the maximum extent of a block or panel, as retrieved from the Max attribute of the object. |
EXTENT_MIN
string |
assems if hierarchy as Assemblies; parts if hierarchy as Parts | The value of the minimum extent of a block or panel, as retrieved from the Min attribute of the object. |
FORCE_UNITS
string |
assems if hierarchy as Assemblies; parts if hierarchy as Parts | The value of the ForceUnits attribute for a ship units object. |
FUNCTIONAL_PROPERTY
string |
assems | The value of the FunctionalProperty attribute for a panel or a group of sub-objects of a panel. |
HEIGHT
string |
assems if hierarchy as Assemblies; parts if hierarchy as Parts | The value of the Height attribute for a plane flange group. |
INCLINATION
double array |
assems | An array of 6 double values is added to each line belonging to pillars, flanges, stiffeners, and faceplates. Each line is provided with two triplets of inclination values to form 2 unit vectors. The vectors indicate the inclinations at the endpoints of the lines in the absolute reference system. |
INSTANCE
string |
assems if hierarchy as Assemblies; parts if hierarchy as Parts | Two possible values: AsDefined or Reflected, to indicate if the object is on the same side as its definition data, or if it has been reflected. |
LEGACY_HIERARCHY
string |
Hierarchy of an entity within a part. Generated when
LENGTH_UNITS
string |
assems if hierarchy as Assemblies; parts if heirarchy as Parts | The value of the LengthUnits attribute for a ship units object. |
MATERIAL
entity |
parts | Plate groups and stiffener groups might contain this metadata which points to the corresponding MATERIAL entity. |
MATERIAL_DIRECTION
string |
faces | The value of the MaterialDirection attribute for a flange, curved panel or knuckled panel. |
MATERIAL_SIDE
string |
assems if hierarchy as Assemblies; parts if hierarchy as Parts | The value of the material side data for a plate group or bracket group. |
MODELUNIT
integer |
comps if hierarchy as Assemblies; parts if hierarchy as Parts | Model units specified in the CAD file.
This is always generated. |
OBJECT TYPE
string |
parts | A string given to parts to indicate their role in the ship organization.
Supported types include:
OFFSET
string |
assems if heirarchy as Assemblies; parts if hierarchy as Parts | The value of the offset data for a plate group. |
PLATE_T
double |
assems if hierarchy as Assemblies; parts if hierarchy as Parts | The value of the thickness attribute for any object having a material whose description includes a thickness. |
RENDERING_TYPE
string |
assems if hierarchy as Assemblies; parts if hierarchy as Parts | The value of the Type attribute for a ship rendering object. |
RootSystemID
string |
assems if hierarchy as Assemblies; parts if hierarchy as Parts | Generated for root system assemblies. Its value is the XML field OID. |
THICKNESS
string |
assems if hierarchy as Assemblies; parts if hierarchy as Parts | The value of the Thickness attribute for a plane flange group. |
TIGHTNESS
string |
assems if hierarchy as Assemblies; parts if hierarchy as Parts | The value of the Tightness attribute for a panel. Allowed values include:
VERSION
string |
assems if hierarchy as Assemblies; parts if hierarchy as Parts | The value of the Version attribute for a ship. |
WEIGHT_UNITS
string |
assems if hierarchy as Assemblies; parts if hierarchy as Parts | The value of the WeightUnits attribute for a ship units object. |
