CFD Ensight Reader Options
The Reader Options dialog partially creates an environment variable in the background. If such a variable is already set, the dialog will read the variable while opening.
![](../../../images/post_processing/cfd_reader_options.png)
In the Reader field, select CFD Ensight Reader. Then, from the drop down menu on the right, select either SC/Tetra ensight files option (to import result files exported from SC/Tetra in ensight format) or the CFD ensight files option (to import result files exported from other solvers, excluding SC/Tetra, in Ensight format).
- Tria6
- Tetra10
- Tria3
- Tetra4
- Quad4
- Pyramid5
- Penta6
- Mass
- Bar
- Hexa8
- Ensight Gold ASCII
- Ensight Gold Binary
- Ensight 6 ASCII
- Ensight 6 Binary
SC/Tetra
ALTAIR_ENSIGHT_FORMAT has to be set to SC/TETRA.
