Browsers supply a great deal of view-related functionality by listing the parts of a model in a tabular and/or tree-based
format, and providing controls inside the table that allow you to alter the display of model parts.
FE geometry is topology on top of mesh, meaning CAD and mesh exist as a single entity. The purpose of FE geometry
is to add vertices, edges, surfaces, and solids on FE models which have no CAD geometry.
Tools and workflows that are dedicated to rapidly creating new parts for specific use cases, or amending existing
parts. The current capabilities are focused on stiffening parts.
It is convenient to apply aerospace loads and concentrated mass that is predefined at specific node ID’s from an Excel
file. This requires carefully numbering nodes with specific ID’s, which is a standard practice in aerospace.
Line loads allow total loads (forces and moments) to be applied in a distributed manner on nodes even though the load
is applied on geometry lines or set of nodes forming ordered edges.
Aircraft windows are normally modeled with CROD elements around the hole of the shells. Constant pressure on the window
area is applied by means of force distribution on the edge nodes.
Use the Transformation Tool to translate, scale, reflect or rotate elements with multiple numbers of copies, including
properties and loads, attached to them.
Use multiple combinations of source files (in the form of CSV) and multiple target models (decks or HyperMesh .dbs) to realize field mapping for the creation of new loads, such as temperature and pressure.
Use the Plot SPC/SPCD tool to display the SPC/SPCD assigned to the nodes in their relevant analysis (output) system.
The tool shows the coefficients of the selected degrees of freedom (DOF) and the ID of the system associated to the
node(s) where the constraint is applied.
multiple numbers of copies, including properties and loads, attached to them.
Loads will also be copied to the new
transformed elements with the possibility to reverse them. ID's can also be assigned
with offset for the newly created elements. Multiple instances (number of copies) can
also be created.
From the Home tools, click the arrow next to the
Move tool, then select Transformation
Tool.
The Transformation Tool dialog opens.
In the Action field, select an action to perform on elements.
In the Entities field, select source elements, nodes, components, or
systems.
When components or elements are transformed, systems are also transformed if
they were created using nodes from those elements or components. If some anchor
nodes are not associated with the transformed element, the association is broken
and a new system is created while transforming using axis definitions rather
than node definitions.
If the system is not associated with elemental nodes that are being
transformed, select systems in the entity selector and it will be transformed as
an axis system.
To create multiple instances, select the Duplicate
checkbox.
In the Destination Component field, select where to organize elements after the
transformation.
Define additional options accordingly.
Click Apply.
Figure 2. Element to be Transformed with Loads Figure 3. Reflected Wing with Loads in a New Load Collector
