Marine 2022.1 Release Notes
Enhancements
The Marine ribbon is no longer available in HyperWorks.
- The Stiffener meshing tools are now consolidated with the 1D Mesh tools.
 - Beam→Shell also migrated to the Mesh ribbon and is now called Inflate. The tool is enhanced to support shell beamsection and create properties. A new tool is added to convert standard beamsections to solids.
Feature CAD Property is not useful any more for property realization from metadata and is replaced by in the Part Browser.
- The only known limitation is that material realization is always a default Steel without considering metdata on the material entity.
 - The "CAD Property" feature is still available in the Model ribbon under the Setup group as backup for material realization.
