Undo-Redo
Undo and redo actions performed in HyperWorks.
By default, the number of undo actions is set to 100 and the maximum undo memory (MB) is set to 2500. You can modify both of these settings by going to .
Undo/redo history may use a large amount of memory. By default, a threshold of 80% of the total memory limit will not be exceeded. Once the memory threshold is exceeded, all older actions will be automatically purged.
- Undo an action by clicking from the menu bar, or pressing Ctrl+Z.
- Redo an action by clicking from the menu bar, or pressing Ctrl+Y.
HyperView Supported Actions and Known Limitations
Supported Actions
- Components, Systems, Assemblies, Includes, Parts, Model files, Materials and Properties.
Known Limitations
- Not all actions can be undone or redone.
- For example, creation and deletion of any entities such as notes is not recorded at this time. This will be addressed in a future release.
- Undo/Redo of Apply style operation does not dynamically update the visibility and FE style of the components in the browser.
- There are a few cases where an action could get recorded as more than one operation in the undo stack. In such cases, you might have to click on Undo/Redo several times to completely reverse the action.
