MASSTOH3D
I/O Options EntryThe MASSTOH3D command can be used in the I/O Options section to request the output of the mass matrix to the .h3d file.
MASSTOH3D = option
| Argument | Options | Description |
| option | <YES,
ALL, NO,
NONE, blank> Default = ALL |
- Mass matrix is not output if this card is not present.
- This option is only for use with MotionView's MBD Flexbody utility.
