ROTATION
I/O Options EntryThe ROTATION command can be used in the I/O Options or Subcase Information sections to request the output of rotation information for all subcases or individual subcases, respectively.
ROTATION (format, form) = option
| Argument | Options | Description |
| format | <HM, H3D, OPTI, PUNCH, OUTPUT2, PATRAN, APATRAN, blank> |
| form | <COMPLEX, REAL,
IMAG, PHASE,
BOTH, blank> Default = COMPLEX |
| option | <YES,
ALL, NO,
NONE, SID, blank> Default = ALL |
- When a ROTATION command is not present, rotations are not output.
- The form argument is only applicable for frequency response analysis. It is ignored for other analysis types.
- The form BOTH does not apply to the .frf output files. Results are output to these files using the rectangular form of complex output when BOTH is the chosen form.
- Multiple formats are allowed on the same entry; these should be comma separated. If a format is not specified, then this output control applies to all formats defined by OUTPUT or FORMAT commands for which the result is available. See Results Output by OptiStruct for information on which results are available in which formats.
- Multiple instances of this card are allowed; if instances are conflicting, the last instance dominates.
- For optimization, the frequency of output to a given format is controlled by the I/O Option OUTPUT.
