An explicit is solved by calculating results in small time increments or time steps. The size of the time step depends
on many factors but is automatically calculated by Radioss.
Composite materials consist of two or more materials combined each other. Most composites consist
of two materials, binder (matrix) and reinforcement. Reinforcements come in three forms, particulate,
discontinuous fiber, and continuous fiber.
Optimization in Radioss was introduced in version 13.0. It is implemented by invoking the optimization capabilities of
OptiStruct and simultaneously using the Radioss solver for analysis.
Interface TYPE8 is used to simulate drawbeads. This interface is mainly used in the process
industry to model metal forming. Drawbeads are
used to prevent the metal strip from sliding
during the stamping process. Figure 1. Stamping Process
The modeling of the drawbeads using interface TYPE8 consists in defining a line of secondary
nodes and a main surface. The set of secondary nodes must be sorted since the input force is
a force per unit length, and the length is computed as the distance between two successive
secondary nodes. As soon as a secondary node projects onto a main surface, a tangential
force is applied to all main nodes to counter their tangential velocity (Figure 2).
Consequently the metal strip does not slide. Figure 2. Drawbead Force
Note: The global force acting on the main surface cannot be greater than the drawbead
force per unit length (user-defined) multiply by the distance of two successive secondary
nodes. In that case, sliding of the metal strip will occur.
Common Problem
In case the drawbead is not continuous, it is necessary to create several TYPE8 interfaces, one
interface for each continuous drawbead. Otherwise,
the drawbead force can be far too high between two
successive nodes that are not part of the same
Figure 3
illustrates this point. The grey part could be a
car hood, and three drawbeads are needed during
the stamping process. If only one interface TYPE8
is created, as the drawbeads are not continuous,
the distance between node N17 and N18 is much
larger than the average distance between two
successive nodes. Therefore, the drawbead force
applied to nodes N17 and N18 could be too high,
leading to unrealistic deformation in these
areas. Figure 3. Example of Hood Stamping
