File Extensions and Formats
Radioss format 2022 uses the 12x extension format.
4x Extension Format 12x Extension Format Type Format Remark Read by Written by
RunnameD00 Runname_0000.rad Starter input ASCII   Starter HyperCrash
HyperMesh
N/A Runname.radopt
(13x extension)
Optimization Input ASCII   OptiStruct HyperCrash
HyperMesh
RunnameDnn Runname_run#.rad Engine input ASCII   Engine HyperCrash
HyperMesh
RunnameRnn Runname_run#_cpu # [_C].rst Restart file Any Default binary Engine Starter
Engine
RunnameAnnn RunnameAnnn Animation IEEE binary   HyperView Engine
N/A Runname.h3d Animation H3D   HyperView Engine (starting in 2018) or HvTrans through run script
RunnameTnn if Radioss Engine option /TH/VERS/41 is used (default):
RunnameTnn
if Radioss Engine option /TH/VERS/51 is used:
Runname_run#.thy
Time history Any Default IEEE binary HyperGraph Engine
RunnameTnnx if Radioss Engine option /TH/VERS/41 is used (default):
RunnameTnnx
Runname_run#_x.thy
"x": letter (a to i)
Runname@Tnn Runname_run#_@.thy MNOISE file Any   HyperGraph Engine
RunnameLnn Runname_run#.out Listing ASCII     Engine
RunnameYnnn Runname_nnnn.sty or RunnameYnnn
according to /IOFLAG
if Irootyy = 2:
RunnameYnnn
if Irootyy ≠ 2:
Runname_run#.sty
Output ASCII   Starter Engine
N/A Runname_nnn#.sta State file ASCII   Starter Engine
  Runname_nnnn.dynain State file with LS-DYNA format ASCII     Engine
RunnameCnn Runname_run#.ctl Control file ASCII   Engine User
  1. Maximum Runname length is 80 characters and the characters "/" and "\" may not be used.
  2. run#: Radioss run number (four digits) from 0000 to 9999.
  3. cpu #: number of SPMD processors (four digits) from 0001 to 9999.
  4. C: restart letter (see /RFILE/n in the Radioss Engine Input manual).
  5. In case of Single File Input, Engine options can be added into Starter file. See Single File Input for details.
  6. Though the current version of Radioss is able to read 4.x extension input files, output files always follow 12.x extension format.
