/IOFLAG
Block Format Keyword Describes the input-output flags.
/IOFLAG
Ipri     Ioutp OutyyFmT Irootyy Idrot
Definition
Ipri Starter output printout flag.
= 0
Reduced printout (including part mass and inertia).
= 1
0 + rigid walls + interfaces.
= 2
1 + boundary conditions + nodal masses + initial velocities.
= 3
2 + ale tables.
= 4
3 + nodes coordinates.
= 5
4 + element connectivities + initial penetrations in contacts + deactivated elements from rigid bodies (full printout).
(Integer)
Ioutp Output a STY model file flag.
= -1
Do not output STY model file .
= 0 (Default)
Set to -1.
= 1
Write out ASCII STY model file, Runname_0000.sty.
(Integer)
OutyyFMT STY file output format flag.
= 2
Format 44.
2 (Default)
Format 51.
(Integer)
Irootyy STY file name flag.
= 2
Ynnn writing file format is RunnameYnnn (old format).
2 (Default)
Ynnn writing file format is Runname_run#.sty.
(Integer)
Idrot Force computation of rotational DOF flag.
= 0
Rotational DOF not always calculated.
= 1
Force computation of rotational DOF.
(Integer)
  1. run#: Radioss run number (four digits) from 0000 to 9999.
  2. OutyyFmT = 2 is only working if all IDs (node, element, ...) are using less than 9 digits.
  3. Only Binary 64-bit restart file can be used.
