/INTER
Engine Keyword Describes an interface.
/INTER
inter_ID Nsearch Tstart Tstop
Definition
Field | Contents | SI Unit Examples |
inter_ID | Interface identifier. | |
Nsearch | Search of closest node
every Nsearch
cycle. Default = 10 |
Tstart | Start time. | |
Tstop | Stop time. Default = 1030 |
- An interface can be activated and deactivated using Tstart and Tstop.
- Nsearch is deprecated and no longer used, any value can be set.
