/INTER/HERTZ/TYPE17
Block Format Keyword This interface simulates impact between external surfaces of two brick groups. The external surfaces can only be 16-node thick shell (/SHEL16) elements.
![inter_type17_hertz](../../../images/solvers/inter_type17_hertz.png)
/INTER/HERTZ/TYPE17/inter_ID/unit_ID | |||||||||
inter_title | |||||||||
grbrc_ID1 | grbrc_ID2 | ||||||||
Fric |
Definition
inter_ID | Interface
identifier. (Integer, maximum 10 digits) |
unit_ID | Unit Identifier. (Integer, maximum 10 digits) |
inter_title | Interface
title. (Character, maximum 100 characters) |
grbrc_ID1 | First brick group
identifier (16-node thick shells group). (Integer) |
grbrc_ID2 | Second brick group
Fric | Coulomb
friction. (Real) |
- Both surfaces are defined with two brick IDs and not surface IDs.
