/MADYMO (Obsolete)
Engine Keyword Activates MADYMO- Radioss coupling.
/MADYMO/Keyword2
lunit tunit munit
Definition
Keyword2
ON
Activates the MADYMO- Radioss direct coupling.
lunit Length unit conversion factor, must be 1 meter in Radioss model unit.
tunit Time unit conversion factor, must be 1 second in Radioss model unit.
munit Mass unit conversion factor, must be 1 kg in Radioss model unit.
  1. /MADYMO/ON requires MADYMO 6.3.1 or higher installation and specific Radioss executables.
