PRES
A simple perfect gas monitored volume where the relative pressure is a function of relative volume or a function of time.
In the PRES monitored volume, the relative pressure is defined as Prel = pressure inside of monitored volume - atmospheric pressure.
The relative pressure is defined using a function in one of two ways. By default, the relative pressure is defined as a function of the relative volume Prel(V0V) , or the pressure can be a function of time Prel(t) .
