/RIVET (Obsolete)
Block Format Keyword Describes the rivet or spotweld.
| /RIVET/part_ID | |||||||||
| rivet_ID | node_ID1 | node_ID2 | |||||||
Definition
| part_ID | Part identifier of the
block. (Integer, maximum 10 characters) |
| rivet_ID | Rivet
identifier (Integer) |
| node_ID1 | Node identifier
1 (Integer) |
| node_ID2 | Node identifier
2 (Integer) |
- The identifier must be unique in each element family, but it is advised for each element type to have a unique element identifier in the global model.
- More than one rivet block can be used to define a part.
- Any number of rivets can be defined in one block.
- A rivet is a rigid link between two nodes.
- A rivet is a kinematic condition, but its input is similar to that of an element.
