/THERMAL
Engine Keyword Thermal analysis.
/THERMAL
time-factor
Definition
time-factor Factor to speed-up the thermal analysis
Default = 1
  1. The physical time will be reduced by time-factor. All thermal properties will be automatically scaled, no need to change the Radioss Starter inputs. Time values in Radioss Engine input file must be modified.
  2. Works for thermal analysis with solid, shell and sph elements.
