An exploration is a DOE or optimization simulation. Each exploration must include design variables and responses.
Optimizations must also include an objective and optionally constraints.
Design variables are changes of the geometric variables that influence the performance of certain analyses. Geometric variables may be sketch dimensions, lengths, angles, or push/pulls. Geometric constraints are minimum and maximum values for
the defined variables. These constraints are specified in the Design Variable tab and the variable's value
will vary within the exploration.
Predict response values resulting from different design variable choices.
Trade-off is not available for Optimization explorations.
From the Design Explorer ribbon, Evaluate tool group, click the
Results Explorer tool.
The Results Explorer browser opens.
In the Results Explorer browser, click the Trade-off
icon .
In the Inputs area, move the sliders to the desired values, or type values into
the Value column.
Review the predicted response values in the Responses area.
Note:
The Min and Max values in the Responses area indicate the minimum
and maximum sampled values for the given responses based on the DOE
results.
The R-Squared value is a statistical representation of the quality
of a given response fit based on cross validation. R-Squared values
will be color-coded to indicate the level of confidence that should
be attributed to a given fit. The trade-off tool is very useful for
showing trends. It is recommended that a verification run be
performed to validate a predicted response.
Optional: Click the Predict button.
Using advanced machine learning techniques, predicted displacement results
are calculated and contoured for the entire model. With the Predict button
active, moving the input sliders will calculate new predicted results,
generating an updated contour without needing to run additional solver jobs.
You can use deformed shape and animation controls to further interrogate the
predicted results.
Note:
The prediction feature requires the EngDataSciFieldPredict
license feature.
To use the Predict button, you have to have selected
Generate Reports - Field Prediction
in the Evaluate dialog when evaluating the exploration. Or, you
can click Generate FP Report to generate
a new report based on the exploration results. Depending on the
model size and number of runs, this may take several
minutes.
Restriction: Field Prediction reports require
displacement results to be present in the exploration simulation
results.
Optional: Click the Verify button, Export,
and Run a verification.
A verification is an exploration where a single solver job is run with the
input design variable values set as they were in the trade-off panel.Figure 2.
Results for the verification exploration run can
be used to verify the predictions. The results can be viewed in the Results
Explorer by setting the verification exploration as the exploration.Figure 3.
