What are Some HX Solver Error Codes?
| Error Number | Description | Reason | Solution | |
| 1 | ERROR 8604 | >>>>Error in Numerical Factorization Phase ***ERROR 8604: Error accessing Sparse Solver scratch files. This may be caused by insufficient disk space or by making multiple runs with the same file prefix and temp directory. ****SOLVER ERROR STOP**** |
| 2 | PH1820HX_DCT | Error happening when computing gap thickness | Tolerance issue |
| 3 | PH02318melem.ff | Stopped during static condensation | Cannot perform static condensation for multiple LHS & RHS | This will not occur for commercial versions |
| 4 | PH02246melem.ff | Failed during static condensation | Diagonal is almost zero | Check if the mesh has bad elements (large aspect ratio, small angles) |
| 5 | PH00104hxdriv.ff | Wrong equation solver | Selected unsupported equation solver | Enter "sparse" or leave blank after "solve" command in *.hx file |
| 6 | PH00517ifldriv.ff | Stopped while computing stress | Wrong component | Please contact hxsupport@altair.com and send all data files |
| 7 | PH00823ifldriv.ff | Trying to solve transport equation | Calculation of element matrices | Check problem type in "load" command. This is supported only for Metal Extrusion and Polymer Processing |
| 8 | PH01137ifldriv.ff | Stopped while computing stress | Wrong component | Please contacthxsupport@altair.com and send all data files |
| 9 | PH0075impflw.ff | Solution algorithm not supported | Selected wrong solution algorithm | Please contact hxsupport@altair.com and send all data files |
| 10 | PH155MEMPARK | Error during memory allocation | Requested array size is zero | Please contact hxsupport@altair.com and send all data files |
