Tool Material Properties
The Tool material type is similar to the Solid material type and is a parameter used with the BEGIN MATERIAL data block. This material must be used when solving conjugate heat transfer problems. For Tool, HyperXtrude allows you to specify the conductivity in the form of diagonal tensor.
| Tool | Steel | { |
| Density = | p | |
| SpecificHeat = | Cp (T) | |
| XConductivity = | K (T) | |
| YConductivity = | K (T) | |
| ZConductivity = | K (T) | |
| VolumetricHeatSource = | Qvol | |
| CoeffOfThermalExpansion = | β | |
| YoungModulus = | E | |
| PoissonRation = | ν } |
| Density | Real (Constant) | Density of tool material |
| SpecificHeat | Real (Constant/Function of Temp.) | Function can be a TABLE1 or EXPRESSION |
| XConductivity | Real (Constant/Function of Temp.) | Function can be a TABLE1 or EXPRESSION |
| ZConductivity | Real (Constant/Function of Temp.) | Function can be a TABLE1 or Expression |
| VolumetricHeatSource | Real (Constant) | Value per unit volume. |
| CoeffOfThermalExpansion | Real(Constant) | Coefficient of thermal expansion. |
| YoungModulus | Real (Constant/Function of Temp.) | Young's modulus of tool material |
| PoissonRatio | Real(Constant) | Poisson ratio of tool material |
