Solid Material Properties
The Solid material type is a parameter used with the BEGIN MATERIAL data block. This material must be used when solving conjugate heat transfer problems.
| Solid | Steel | { |
| Density = | p | |
| SpecificHeat = | Cp (T) | |
| XConductivity = | K (T) | |
| YConductivity = | K (T) | |
| ZConductivity = | K(T) | |
| VolumetricHeatSource = | Qvol | |
| CoeffOfThermalExpansion = | β | |
| YoungModulus | E | |
| PoissonRation = | ν } |
