Tutorial: Adding a Resin Material
Add a new Resin material to the Material Database.
Polymeric resins are broadly classified into thermoplastic and thermoset resins. A typical RTM process uses thermoset resin which requires curing of the resin after the infusion process. Inspire RTM support resin material models that can be used for thermoset resins and to some extent thermoplastic resins.
The complete list of data used is:
- Density
) - Thermal conductivity
- Specsific heat
- Viscosity Model
- None
- Carreau Yasuda
- Temperature dependence
- None (should be used with Newtonian)
- Arrhenius
- WLF
- Curing Kinetics Model
- None
- Generalized curing kinetics model
- Constant Rate curing kinetics model
Carreau—Yasuda Model
Infinite shear viscosity
Zero shear viscosity
Carreau Constant (use 1)
Time Constant
Power-law index
Transition parameter
Temperature Dependence
Arrhenius Function
Activation energy
Universal gas constant
WLF Function
WLF Constant 1
WLF Constant 2
Reference Temperature
Constant Rate Model
Gelation cure
Gelation time
Generalized Curing Kinetics Model
Nth order coefficient
Nth order exponent
Autocatalytic coefficient
Autocatalytic exponent 1
Autocatalytic exponent 2
Gelation Model
This is related to curing kinetics and describes how the viscosity increases wi
Gelation cure
Gelation viscosity constant C1
Gelation viscosity constant C2
Latent Heat
Latent heat of curing
