Direct Generation - Result
Result Tab
- Top: Displays the result of top placed parts.
- Bottom: Displays the result of bottom placed parts.
- Top-Deleted: Displays the list of deleted parts among the parts placed on the top layer.
- Bottom-Deleted: Displays the list of deleted parts among the parts placed on the bottom layer.
Edit and Confirm
- Edit Mode: Can modify the part's coordinates and angle from the generated mounting coordinate data results.
- Set Mounting Part Code: Set mounting part code.
- Confirm: This button is applied after editing the coordinates and angle of the part in Edit Mode.
Result Table
- Reference Name: Refers to the reference name on the PCB design.
- Part Code: Refers to the part code.
- Mounting Part Code: Refers to the part code in Mounting Part Code Matching Table.
- X: Refers to X coordinate of part.
- Y: Refers to Y coordinate of part.
- Angle: Refers to angle of part.
- Property: Refers to part’s value in property.
- Result Information: Refers to comment of each result.
- Change to Alternative Component: Can replace part code to alternative part.
Save and Export
- Delete: Can delete the selected part.
- Export Block Data: Exports the mounting coordinate data of the sub board designated as a block as a text (*.txt) file.
- Export MS Excel: Can export the generated result to Excel file through Direct Generation menu.
- Export: Mount data of the mounter format selected on the Direct Generation Setting screen can be exported.
- User Defined Export: Exports mount data in user defined
format.
- Board Size: Sets the information of board size.
- Title String: Sets the string for title.
- Column Count: Sets the number of columns.
- Table: Sets exporting format for each column.
- Origin Location: Sets exporting format for board origin.
- Origin Offset: Sets offset information of origin.
- Fiducial Mark: Sets exporting format for fiducial mark.
- Fiducial Light: Sets exporting information of fiducial light.
- Placement Coordinate: Sets exporting format for part placed
coordinates.
- Array Count: Sets exporting format for array board information of
sub board.
- Array Coordinate: Sets exporting format for each sub board’s
origin.
- OK: Saves the user-defined format Mount Data as a text (*.txt) file.
Click Save As to save the created part coordinate data (*.MEMD) file. Click Load to load the saved coordinate data (*.MEMD) file.
