Change Board Origin
If the origin point of PCB design is incorrect, you can change its origin point with this function.
- Origin and left bottom of board outline are away. Click Set Origin to Let Bottom to move origin based on left bottom of board outline. At this time, difference is calculated, it can see values in X, Y-Coordinate.
- Object Select: Select the object to be origin.
- After specifying new origin point, click Save/Upload to will change the origin point of board.
- To go back to initial status click Initialize Board Origin.
