Copper Keep-out Around Pad
- Target Layer Definition: Define target layer(s).
- Component placed Layer: Target layer will be same layer with component placed layer.
- All Layers: Top, bottom, and inner physical layers will be target layers.
- Component Group Definition: Define target components.
- Component Group Selection: Select component from component group list.
- Checking
- Clearance between Component’s Pad and Copper: Set the clearance value between component pad and copper-pours.
- Except Thermal Pad: Option for excluding thermal pads in checking.
