General IC
This item tracks the voltage and signal lines in the circuit, calculates the voltage value of each net, and checks whether the all general IC connected to the net is within the allowable voltage range.
- Component: Select General IC component group to be checked.
- V_Input Pin:
Assign power input pin information of regulator. You can assign pin number
using Pin Number or Pin Property which contain pin number information.
Figure 2. - Power Net: Select power net group to which General IC components are connected.
- Ground Net: Select ground net group to which General IC components are connected.
- Recommended
Operating Minimum[V]: Set the allowable recommended operating minimum power
input voltage of this component. You can set this by entering the allowable
value directly or select the property name which contain allowable
value.
Figure 3. - Recommended
Operating Maximum[V]: Set the allowable recommended operating maximum power
value.
Figure 4. - Absolute
Maximum[V]: Set the allowable absolute maximum power input voltage of this
component. You can set this by entering the allowable value directly or
select the property name which contain allowable value. You can also assign
tolerance of this test.
Figure 5.
Stress Test Option
Set whether passive components are considered short or open when navigating signals and power lines.
