Stress Test
Manage and define stress test rule checks.
All components used in digital logic must be used within the allowable voltage range. The stress test item tracks the voltage and signal lines in the circuit, calculates the voltage value of each net, and checks whether all passive component connected to the net is within the allowable voltage range.
