You can create and solve linear buckling problems in structural analysis.
To solve linear buckling, first apply a reference level of loading,
, to the structure.
Then, perform linear static analysis to obtain the stresses needed to form the
geometric stiffness matrix,
, corresponding to
. Calculate buckling loads by solving an eigenvalue
problem. Not all eigenvalues are required; only a small number of the lowest
eigenvalues are normally calculated for buckling analysis.
The lowest eigenvalue
is associated with buckling. The critical, or
buckling, load is calculated as:
(1)
