Thermal Transient
Thermal transient analysis is used to capture the thermal behavior of a system over a specific span of time. Boundary conditions vary with time, but the material properties remain constant. Transient thermal analysis in SimSolid is based on modal superposition method.
Setup
- Specify the number of modes.
- Specify the time span.
- Specify the initial temperature.
- Select the Evaluate peak responses during solving check box to evaluate peak response during solution phase.
