A spot weld connects two parts over a circular area on the contacting surfaces. A laser weld connects the contacting
surfaces over an area created from solids or strip created along a user-drawn line or a polyline.
Spot and Laser Welds
A spot weld connects two parts over a circular area on the contacting surfaces. A laser weld connects the contacting surfaces over an area created from solids or strip created along a user-drawn line or a polyline.
