Geometry Import Settings
Options for defining treatment of geometry before import.
To access these settings, on the menu bar click .
- Face faceting parameters
- SimSolid uses lightweight facets to represent part faces. Assembly, part names, and hierarchy are retained. Default facet settings should be sufficient for most geometries, but adjustments can be made.
- Always check part overlaps on import
- This feature is similar to the Check Geometry Defects function. Since this may take time, checking the model on import allows you to disable the option in the Assembly workbench if desired.
- Use Parasolid reader
- In general, the Parasolid reader is the preferred data path. However, if problems are encountered, use the other data path by clearing the check box.
- Import materials
- SimSolid will attempt to look for and read
any part metadata attribute that contains the material property name
string. If this name string matches an existing name in the SimSolid
material database, the corresponding SimSolid material properties will be applied. If it is not found, SimSolid will notify the user that material
properties cannot be applied.Note: SimSolid does not support the general imprint of CAD Material property data. The Import materials option will not work with all CAD files, as SimSolid currently supports CATIA, NX, and JT only. See the Define Custom Material Database topic for information on how to duplicate material property definitions present in the CAD system.
- Custom metadata attributes
- You can list any custom metadata attributes desired in the text box. SimSolid will search in the order listed and these values will take precedence over any internal default values.
