Material Properties
Material properties define the structure and thermal characteristics of each part in the assembly.
For all analyses' density, Young’s modulus, Poisson’s ratio, thermal conductivity, and coefficient of linear expansion must be defined. Additionally, material yield strength is used to calculate factors of safety. For fatigue analysis, fatigue properties must be specified by estimating from UTS or input of Stress-Life or Strain-Life curve parameters.
