Test No. VT03 For a cylinder loaded with a prescribed heat flux, find the temperature at the boundary between where flux is applied
and the rest of the side surface.
SS-V: 3000 Cooling fin Test No. VT01 Find the temperature of the insulated end of a cooling fin surrounded by fluid with the other end maintained at constant temperature.
SS-V: 3010 Insulated Wall Test No. VT02 Find temperatures at firebrick and insulating brick surfaces in an insulated wall.
SS-V: 3020 Cylinder with Prescribed Heat Flux Test No. VT03 For a cylinder loaded with a prescribed heat flux, find the temperature at the boundary between where flux is applied and the rest of the side surface.
SS-V: 3030 Heat Generating Plate Test No. VT04 Find temperature at the mid-plane of a heat generating steel plate and the heat flow rate to the fluid the plate is heating.
