SS-V: 1020 Curved Beam Test No. VS03 Find tip deflections of a curved beam when subjected to in-plane and out-of-plane loads.
SS-V: 1030 Simply Supported Thin Plate Test No. VS04 Obtain the displacement at the center of a simple supported thin plate for concentrated load and uniform pressure load.
SS-V: 1040 Clamped Thin Plate Test No. VS05 Obtain the displacement at the center of a clamped thin plate for concentrated load and uniform pressure load.
SS-V: 1050 Tapered Solid Bar Test No. VS06 Determine the maximum axial deflection and axial stress at the mid-length for a tapered solid bar.
SS-V: 1060 Cantilever Plate Test No. VS07 Find bending stress at fixed end for a cantilevered plate subjected to a vertical shear load of 120 lbs.
