Test No. VS10 Find the stress concentration in a filleted
notch.
Definition
The large shaft face is fixed.
The load is 1MPa external pressure on the smaller shaft face. Run
analysis with 5 adaptive passes and "Adapt to features" on.
The units are SI.
The model parameters are:
- Parameters
- Value
- D
- 120 mm
- d
- 60 mm
- r
- 3 mm
- D/d
- 2
- r/d
- 0.05
Results
The reference solution is given
by:
(1)
The following table summarizes the stress results.
Theory |
SimSolid |
% Difference |
SZ Stress [MPa] |
2.6000E+00 |
2.4460E+00 |
-5.92% |
