SS-V: 1030 Simply Supported Thin Plate
Test No. VS04 Obtain the displacement at the center of a simple supported thin plate for concentrated load and uniform pressure load.
Definition
A square plate simply supported on four edges (Figure 1) is subjected to the following loads (Figure 2):
- uniform pressure
- concentrated load
The units are IPS.
Because solid model is used, boundary conditions on supported edges are applied along middle lines of these edges (Figure 3).
- Properties
- Value
- Modulus of Elasticity
- 1.7472e+7 psi
- Poisson's Ratio
- 0.3
Results
Theory (Kirchoff's Plate Bending Model) | SimSolid | % Difference | |
Uniform load | 4.0620E-06 | 4.0700E-06 | 0.20% |
Point load | 1.1600E-05 | 1.1610E-05 | 0.09% |
