SS-V: 1070 Plate with a Hole
Test No. VS08 Find the maximum stress of a plate with a hole.
Definition
Due to symmetry, only ¼ section was analyzed (Figure 1).
The units are SI.
Sliding constraints applied to the left, back, and bottom faces.
The load is 5000N applied to the right face.*
The model parameters are:
Value
L
100mm
H
50mm
R
20mm
F
100N/mm2
Thickness
1mm
The material properties are:
Properties
Value
Modulus of Elasticity
2.1e+11
Poisson's Ratio
0.3
Results
The reference solution is given by:(1)
σmax= kσnom MathType@MTEF@5@5@+=feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLnhiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr4rNCHbGeaGqiVCI8FfYJH8YrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbba9q8WqFfeaY=biLkVcLq=JHqpepeea0=as0Fb9pgeaYRXxe9vr0=vr0=vqpWqaaeaabiGaciaacaqabeaadaqaaqaaaOqaaabaaaaaaaaapeGaeq4Wdm3damaaBaaaleaapeGaamyBaiaadggacaWG4baapaqabaGcpeGaeyypa0JaaiiOaiaadUgacqaHdpWCpaWaaSbaaSqaa8qacaWGUbGaam4Baiaad2gaa8aabeaaaaa@4325@
With k = 3.
σnom= Fhhr=166,7MPa MathType@MTEF@5@5@+=feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLnhiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr4rNCHbGeaGqiVCI8FfYJH8YrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbba9q8WqFfeaY=biLkVcLq=JHqpepeea0=as0Fb9pgeaYRXxe9vr0=vr0=vqpWqaaeaabiGaciaacaqabeaadaqaaqaaaOqaaabaaaaaaaaapeGaeq4Wdm3damaaBaaaleaacaWGUbGaam4Baiaad2gaaeqaaOWdbiabg2da9iaacckacaWGgbWaaSaaaeaacaWGObaabaGaamiAaiabgkHiTiaadkhaaaGaaGPaVlabg2da9iaaykW7caaIXaGaaGOnaiaaiAdacaGGSaGaaGjbVlaaiEdacaWGnbGaamiuaiaadggaaaa@4D9E@
k= 33.13dh+3.66dh21.53dh3=2.2357 MathType@MTEF@5@5@+=feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLnhiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr4rNCHbGeaGqiVCI8FfYJH8YrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbba9q8WqFfeaY=biLkVcLq=JHqpepeea0=as0Fb9pgeaYRXxe9vr0=vr0=vqpWqaaeaabiGaciaacaqabeaadaqaaqaaaOqaaabaaaaaaaaapeGaam4Aaiabg2da9iaacckacaaIZaGaaGPaVlabgkHiTiaaykW7caaIZaGaaiOlaiaaigdacaaIZaWaaeWaaeaadaWcaaqaaiaadsgaaeaacaWGObaaaaGaayjkaiaawMcaaiaaykW7cqGHRaWkcaaMc8UaaG4maiaac6cacaaI2aGaaGOnamaabmaabaWaaSaaaeaacaWGKbaabaGaamiAaaaaaiaawIcacaGLPaaadaahaaWcbeqaaiaaikdaaaGccaaMc8UaeyOeI0IaaGymaiaac6cacaaI1aGaaG4mamaabmaabaWaaSaaaeaacaWGKbaabaGaamiAaaaaaiaawIcacaGLPaaadaahaaWcbeqaaiaaiodaaaGccaaMc8Uaeyypa0JaaGPaVlaaikdacaGGUaGaaGOmaiaaiodacaaI1a GaaG4naaaa@61C8@
σmax=372.7MPa MathType@MTEF@5@5@+=feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLnhiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr4rNCHbGeaGqiVCI8FfYJH8YrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbba9q8WqFfeaY=biLkVcLq=JHqpepeea0=as0Fb9pgeaYRXxe9vr0=vr0=vqpWqaaeaabiGaciaacaqabeaadaqaaqaaaOqaaiabeo8aZnaaBaaaleaaciGGTbGaaiyyaiaacIhaaeqaaOGaaGPaVlabg2da9iaaykW7caaIZaGaaG4naiaaikdacaGGUaGaaG4naiaad2eacaWGqbGaamyyaa aa@450B@
The following table summarizes the maximum stress.
  Theory SimSolid % Difference
Maximum Stress [MPa] 3.7270E+02 3.7775E+02 1.35%
*To determine the load: 100N/mm2 x 50mm x 1mm.
