Test No. VS17 Find the stress concentration in a
grooved shaft.
Definition
The shaft is fixed on one end. A bending moment of 98125 N-mm is applied on the other
end. Bending stress is calculated as 1 MPa using the equation below.
(1)
σ
0
= Mc/l
MathType@MTEF@5@5@+=
feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn
hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr
4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9
vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x
fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaae4WdmaaBa
aaleaacaqGWaaabeaakiaaykW7caqG9aGaaGPaVlaab2eacaqGJbGa
ae4laiaabYgaaaa@3F52@
Where,
c
fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaae4yaaaa@36D9@
d/2
l
fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaaeiBaaaa@36E2@
πd4 /64
The units are SI.
The model parameters are:
Value
r
25 mm
D
150 mm
d
100 mm
r/d
0.25
D/d
1.5
Results The following table summarizes the stress results.
Theory1
SimSolid
% Difference
σ
y
aaleaacaqG5baabeaaaaa@3864@
Bending Stress [MPa]
1.5
1.5
NIL
1 Page 1030 ,
Shigley’s Mechanical Engineering Design, Ninth Edition, Richard G Budynass and J.
Keith Nisbett
