Van Der Pol’s nonlinear dynamic system is represented in the following differential equation:
where at least one of the following initial conditions is met:
This section steps you through the process of building Van Der Pol’s system in block diagram form, and generating ABCD state-space matrices, transfer function information, and Bode and root locus plots.
