The File > Print command lets you choose a printer and select printing options, such as the number of copies, the layers to be printed, and so on. You can also set up printer options by clicking on the Setup button in the Print dialog box. Use the File > Page Setup command to specify margins, headers, and footers.
To print a block diagram
1. Do one of the following:
• From the toolbar, choose .
• Choose File > Print (CTRL+P).
2. Do one or more of the following:
To print |
Do this |
Multiple copies |
In the Copies box, enter a number. |
The current level of the diagram |
Under Print Range, activate Current Level. |
The current level and below |
Under Print Range, activate Current Level and Below. |
All levels of the diagram |
Under Print Range, activate All. |
Each level of the diagram on a separate page, and when necessary, reduce diagram text so the level fits on a single page |
Activate Fit to Page. Because Embed prints each
level with the minimal reduction possible, the levels of a multi-level
diagram may be sized differently. |
What is currently displayed on the screen |
Activate Print Current View. Embed prints what you see on the screen, starting at what is in upper left corner of the screen. |
Each level using as many pages as necessary to print it without resizing |
Activate Tile Pages. The margin settings are honored for each page. |
A version of the diagram to a file to be printed later or to be used in another program |
Activate Print to File and then click OK, or press ENTER. In the ensuing dialog box, specify a name for the diagram you want to print.
