Creating a Dielectric Cuboid
Create a cuboid and set the region medium to teflon.
Create the cuboid.
On the Construct tab, in the Create solid group, click the
Cuboid icon.
- Create the cuboid using the Base corner, width, depth, height definition method.
Use the following dimensions:
Dimension Value Base corner (C) (0, 4, 0) Width (W) 5 Depth (D) 5 Height (H) 5
- Select Cuboid1 in the model tree.
- Right-click the region in the details tree and from the right-click context menu select Properties.
On the Region properties dialog, set the
Region medium to Teflon.
- Click OK to close the dialog.
