Creating a Linear / Planar Antenna Array
Create a linear or planar finite antenna array model.
On the Construct tab, in the Structures
group, click the
Planes/arrays icon. From the drop-down list, select the
Linear/planar array icon.
Specify the elements in the U dimension.
- Under U dimension, in the Number of elements field, specify the number of array elements.
- Under U dimension, in the Offset along X axis field, specify the offset between the array elements.
Specify the elements in the V dimension.
- Under V dimension, in the Number of elements field, specify the number of array elements.
- Under V dimension, in the Offset along Y axis field, specify the offset between the array elements.
In the Label field, add a unique label for the antenna
array.
Click the Distribution tab to specify the array
distribution.
- To create an antenna array with a uniform distribution, click the Uniform distribution or calculated from plane wave check box.
- To create an antenna array where the distribution is calculated from the plane wave (if a plane wave is present in the model), click the Uniform distribution or calculated from plane wave check box.
- To create an antenna array with a specified excitation for each element,
clear the Uniform distribution or calculated from plane
wave check box.Note: When specifying each element, take note of the array element indexing.
Figure 1. Image depicting the array element indexing.- To specify the magnitude scaling and phase offset manually:
- In the Magnitude scaling field, specify the excitation magnitude for the individual element relative to the base element.
- In the Phase offset (degrees) field, specify the phase offset (in degrees) for the individual element relative to the base element.
- To specify the magnitude scaling and phase offset by importing the
points from file, click Import.
- In the Filename field, browse for the file you want to import.
- [Optional] In the Scale by field, enter a value to scale the points.
- Under Delimiter, click the delimiter type you use in your file.
- Click OK to close the Import points dialog.
