Converting Configuration Specific Entities to Global
Convert a configuration specific entity to a global configuration.
As an example, loads from a configuration are converted to global loads, but the steps are similar for converting frequency, sources and power.
- In the model tree, click Loads.
- From the right-click context menu, select Specify loads globally.
- On the Choose configuration dialog, from the drop-down list, select the configuration whose loads are to be converted to global loads (and as a result inherited by all configurations).
- Click OK to create the loads and to close the dialog.
