Importing a Medium from File
Import a dielectric, metal or impedance sheet from a .XML file that describes the medium properties.
Select one of the following:
- Create a dielectric. On the Construct tab, in the Define group, click the Media icon. From the drop-down list, select the Dielectric medium icon.
- Create a metal. On the Construct tab, in the Define group, click the Media icon. From the drop-down list, select the Metallic medium icon.
- Create an impedance sheet. On the Construct tab, in the Define group, click the Media icon. From the drop-down list, select the Impedance sheet icon.
- Click Import medium from file.
- In the Filename field, browse for the file you want to import.
- Click Create to import the medium and close the dialog.
