Advanced Solver Settings
Advanced solver settings are available to reduce the memory footprint or speed up a solution for specific types of models.
On the Solve/Run tab, in the
Solution settings group, click the Solver settings icon. On the Solver settings dialog, click the
Advanced tab.
Factorisation for Parallel Execution
- Default
- This option applies the predefined factorisation type adopted by the Solver.
- Auto
- This option applies automatically the optimum factorisation type based on the model.
- Use standard full-rank factorisation
- This option applies the standard full-rank factorisation.
- Use block low-rank (BLR) factorisation
- This option applies the block low-rank (BLR) factorisation.
Compression for Looped Plane Wave Sources
This option is an accelerated method that can be used to speed up the solution for a model that contains a plane wave source that loops over multiple directions (for example, when calculating RCS).
