Subtract From
Create complex geometry by subtracting geometry from an overlapping (target) part.
Figure 1. The
- Subtracting a shell structure (a free space region that implies an empty / hollow closed structure) generates new regions, faces or edges on intersecting geometry. No geometry is removed.
- Subtracting a solid structure (a region that is not set to free space) results in geometry being removed from any intersecting parts.
Figure 2. An intersecting flare and sphere (on the left), flare subtracted from sphere (shell) (middle) and flare subtracted from sphere (solid) (to the right).
