Paraboloid
Create a paraboloid.
Centre point (C) | The apex of the paraboloid. |
| Radius (R) | The radius of the paraboloid aperture, parallel to the UV plane. | |
| Focal depth (F) | The focal depth (F) of the paraboloid is the distance from the centre point (C) to the focal point. If this is negative, the paraboloid is oriented towards the negative N axis. |
The focal depth is related to the dimensions of paraboloid by
