Single Node Names
A node is a point in 3D space. Nodes can be constructed and referenced using variable names. Use a loop to construct multiple nodes.
When defining or using node names, simple variable names of the form
A#i can be used to define the node. If a hash character
(“#”) is found in a node point name, this character and
everything that follows is interpreted as a variable string, evaluated and rounded to
the nearest integer.
As an example, #k=15 and a point defined as P#k, is
equivalent to using P15 as point name. The length of the node name
string (before and after expansion) is limited to 5 characters.
!!for #k = 1 to 20
DP P#k
!!nextThese defined points can then be used individually or inside another loop.
