Custom Point Annotations
A number of custom point annotations definitions are available for a Cartesian graph that allows you the flexibility to annotate any point of interest on the graph.
On the Cartesian
context tab, on the Measure tab, on the Custom annotations group, click the Points icon. From the drop-down list, select the type of annotation you want to
use.
Icon | Icon text | Description |
Global maximum | Place an annotation at the global maximum. |
Global minimum | Place an annotation at the global minimum. |
Specify independent axis value | Place an annotation at a specified independent axis value. |
Second maximum | Place an annotation at the second maximum. |
Second minimum | Place an annotation at the second minimum. |
Other | Opens a dialog where you can specify any of the following custom point
annotations:
