Changing the Marker Styling
Change the marker style, marker colour and marker size for a selected trace.
Select the graph where you want to change the marker style, marker colour and marker size and click the trace.
  1. Change the marker style for the selected trace.
    1. On the Format tab, in the Marker group, click the  Marker style icon.
    2. Select one of the following:
      • To remove markers, click .
      • To add markers, select the marker style you want to use.
  2. Change the marker colour for the selected trace.
    1. On the Format tab, in the Marker group, click the  Marker colour icon.
    2. Select the maker colour you want to use.
  3. Change the marker size for the selected trace.
    1. On the Format tab, in the Marker group, click the  Marker size icon.
      • To select a specified marker size, click the marker size you want to use.
      • To specify a marker size that is not included as one of the default sizes, click Custom.
    3. Select the maker size you want to use.
